Saltar al contenido principal
The Nokia C5-03 is a budget touchscreen smartphone, first released in December 2010.
internal RF port location
How can I find out the RF antenna port location inside the phone. I want to connect an external wired RF cable to that port for some testing purpose.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
3 comentarios
Thanks for your response.
Yes, I would like to use antenna module located on the phone, but how can I find it. Where is the antenna module in this picture?
- de
Pull your module and use the copper contacts where the module connects to the logic board
- de
Yes, I have taken out the module. But I see two RF ports on the PCB. In the Phone schematic these are numbered as X7001 and x7002. How to figureout whichone I should use to solder an external RF cable.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Alok Gaur, may be this will show what you are after. Otherwise, have you consider using the antenna module as a tracing point.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Alok Gaur estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,713
