kernel_task at 240, fan spins normally
Hi all. So I got this iMac 27” Late 2015 with a mechanical HD. It was behaving normally. I left it there sitting for a couple of months. Lately I replaced the HD with an SSD. I noticed it was very slow. Installing Monterey took forever. Monitor activity shows kernel_task at 240/250, but fan spins normally. What I did so far:
- Cleaned all the dust inside of the fan. There wasn’t much anyway
- Replaced the memories with timetec ones as they’re certified
- Replaced the ssd with a brand new samsung one
- Removed the logic board and got rid of the 32 GB blade ssd
- Replaced the PSU board with a known good one as I’ve read it carries thermal sensors which could cause the problem
- Replaced the fan with a known good one
- Diagnostic (cmd-d on startup) shows nothing
- Safe-mode doesn’t change things
There are no apps running, no third party software. Monterey is clean install, including latest update (which also took forever).
Apart from speakers, I can only try to replace the sata cable, the pram battery and the wifi card. If that makes any sense.
Any suggestion would be appreciated.
Thanks everyone.
Es esta una buena pregunta?
