My laptop is not on when I click power button.
my laptop is not on when i click power button.
Es esta una buena pregunta?
Well I will suggest you to check out this video: https://www.youtube.com/watch?v=z0ebMAcw...
If this not help you out in fixing the issue then you can also check out this for more solution: https://www.systweak.com/blogs/fix-lapto...
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 66
@sandeepkum59501 Does the charge light come on when you plug the charger in?
- de Dany
Charger light is on. Laptop still not on when click power button. Battery built in. I cant remove battery to try power on without battery while pluging the charger cable.
- de farid daud
