Saltar al contenido principal
Bypass bluetooth speaker not working without a connected battary
Hello,
I have a very nice looking bluetooth speaker from Teufel called Bamster (no model number, only SN available at the back).
Because the speaker of my monitor are deteriorating I wanted to use the bluetooth speaker with two wires: Micro USB for power and an AUX cable.
To my surprise there was no battery inside, a bigger surprise was that there are no aftermarket batteries in sale ALSO no disassembly videos for this speaker. I guess it wasn't sold for a long time.
Anyway, the battery connector has 3 Pins. I connected it to my power supply, middle pin was ignored and I got it working, I could pair it with my phone and play music. However, no sign of life, if I connect it to the power socket.
How can I bypass the battery is not connected issue? I thought about connecting the 5V micro USB with the + battery connector pin and same with ground. This way I could close the unit and keep the aesthetics. Other way is of course to make a hole and connect straight to the battery connector pins. I guess I have to remove the micro USB to make space for the wires and this way I wouldn't need to drill holes.
I am curious though:
Would you be able to solve this issue, if you would have schematics for the board? I think is not possible, right? There must be some IC which checks the battery. Maybe some kind of a hack would help.
Thank you.
Edit:
I salvaged a small LiPo battery with 3 pins from a 2016 JBL wireless headset with 650 mA and soldered it to the battery connector. With AUX I had a very loud noise but with Bluetooth the speaker works fine. Great sound, great design and I don't need to fix my monitors speakers.
Had to use a Bluetooth dongle to connect to PC. I am worried that the battery will be charging all the time but luckily the battery has a small PCB, in case something goes wrong, I hope it will shut the battery. The led on the device indicates charing, it charges all the time. I hoped it would get the current from the micro USB.
I have to keep testing, because I noticed few things:
-In one of two restarts, I had to reconnect the speaker via the Bluetooth settings in Windows
-I lost audio in game but Windows had sound, had to restart the game, didn't happen again
-The PC is near my bed, the speakers goes in safe mod after 10 and it turns off after 20min. according to manual, I hope it makes no sounds while doing so
-I think I will turn off ErP (USB power after PC shutdown), so the speaker don't draw current.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
it will show its charging anyway, its the same if your phone battery is at 100% it will still show its charging if connected to the charger, a 3 pin connector is likely postive, negative and battery data line, if the battery you connected has 3 wires just make sure each wire is connected to the correct line
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
@tech_ni
Do you have experience with batteries?
I have a new battery for a Bluetooth speaker (JBL Flip4) with 5 wires (2red, 2black and one white).
Could I merge two reds to one red, same with black and connect it to the PCB of the Teufel Bluetooth speaker (which has 3 pins)? I mean I would have 3 wires at the end.
OR should I only connect one red, one black and the battery data line?
- de
@forbiddenfume reds are positive and black are negative, white could be a data line
- de
Añadir tu respuesta
forbiddenfume estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 57
