Saltar al contenido principal
Screen gone blank, only a few vertical lines visible
I got this laptop repaired a few months ago. It was working fine, the repair changed pair of fans, thermal system and lcd. After a few months suddenly the screen got blank and only a few vertical lines are visible while turning it on, which eventually goes away. Can someone help fix it
Update (08/06/23)
Here is the attached image
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Here is the attached image [image|3040735]
- de
Agregar un comentario
1 Respuesta
@abzo connect an external monitor to your laptop. If that displays fine, you know that your LCD is in need of replacement. If it shows the same, the issue could be related to your video circuitry (GPU etc.) and will require some inspection/rework of your motherboard.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Abzo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 28
Todo El Tiempo: 81
