Saltar al contenido principal
Lanzado en junio de 2012 / Procesador Core i7 con Turbo Boost / Hasta 1 GB de RAM de video DDR5
MacBook Pro 2012 not powering on
MacBook Pro 2012 is not booting at all. The charging light is green when connected, however the fans don't spin, there is no chime, and the drive does not spin.
  • Reset of SMC and NVRAM
  • Held power button for 30+ seconds with / without power / battery plugged into logic board
  • Removing all connections from the logic board, and testing each component while trying to turn on
  • The internal components/logic board appear clean and undamaged
  • Check power button cable - all fine
  • No liquid damage / all water spots are untouched
The last thing I could try would be to ensure the board is receiving power with a multimeter, I have one but have no idea where to put the connections for testing.
Any suggestions would be appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I'm not sure if you did this: disconnect the battery and the mag-safe, press and hold the power on button for 15 seconds. Now reconnect the battery then the mag-safe. You should get a spontaneous reboot.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
StuartM estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 130
