No se escucha nada
Se mojo y ahora no se escucha nada
Es esta una buena pregunta?
@mariacardona this could simply be a speaker issue. However, you mentioned that it got wet. That means it can also be a much great problem. You want to treat this like any other water immersed device.
For now you need to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
Next you need to disassemble your phone using something like this video as your guide. You must remove all EMI shields from the circuit boards. After you remove those, clean all the boards (mother board and daughter board also called charging board), connectors and all with +90% isopropyl alcohol. Follow this guide, and even so it was written for an Apple iPhone 3G, all the points are still pertinent to your phone. While you clean your boards, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, you must replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do, would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad speaker and a replacement of that, may fix it.
If after all of that it should still not work, you want to follow this flowchart
To identify the location of the components to check, use the search function of your PDF reader, on this document.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@mariacardona esto podría ser simplemente un problema del altavoz. Sin embargo, has mencionado que se mojó. Eso significa que también puede ser un problema mucho mayor. Usted quiere tratar esto como cualquier otro dispositivo sumergido en agua.
Por ahora, debe dejar de intentar cargar, sincronizar o utilizar el teléfono. Esto potencialmente puede empeorar una mala situación.esto puede dañar aún más su teléfono.
A continuación, tiene que desmontar el teléfono usando algo como este video como su guía. Debe quitar todos los escudos EMI de las placas de circuito. Después de quitarlos, limpia todas las placas (placa madre y placa hija también llamada placa de carga), conectores y todo con +90% de alcohol isopropílico. Siga this guide, y aunque fue escrita para un Apple iPhone 3G, todos los puntos siguen siendo pertinentes para su teléfono. Mientras limpias las placas, comprueba que no haya daños evidentes, como componentes quemados o que falten, etc. Cuando esté bien limpia, debes sustituir la batería. Todos estos pasos son para evitar el fallo retardado causado por la corrosión. Lo mejor seria limpiarla con un limpiador ultrasonico, pero si no tienes acceso a uno, esto al menos ayudara. Una vez hecho esto, vuelva a montar el teléfono y evalúelo de nuevo. Hasta que no se limpie, todo serán suposiciones. Es posible que tenga un altavoz malo y un reemplazo de eso, puede arreglarlo.
Si después de todo esto sigue sin funcionar, siga este diagrama de flujo
Para identificar la ubicación de los componentes a comprobar, utilice la función de búsqueda de su lector de PDF, en este documento Component Layout.
Mientras trabajas en tu teléfono, haz muchas fotos. Una vez que haya terminado con él, tomar esas fotos y crear una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 63
