Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Hp laptop probook 6550b won't turn on
I have a hp laptop probook 6550b But won't turn on at all, even though I remove battery and plug in the charger but it's not turning on the indicator light always turn orange so can someone help me with that
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@darrelelijah not sure why you disconnected your battery. Also, let us know which indicator light is orange. I suggest that you start off with the simple things. First you want to check your power supply. Make sure it has the proper voltages. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. After that you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Darrel Elijah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 23
Todo El Tiempo: 788
