Saltar al contenido principal
El PowerMac G5 es un ordenador de escritorio producida por primera vez en 2003 por Apple Corporation. Esta guía revisará el proceso de reparación de un número de modelo Apple PowerMac G5 A1047 EMC 2061 de 2004.
Preguntas 196 Ver todo
won't power on, I just smack the machine and then it powersup
I have similar issues , it seems to be a cold/cracked solderjoin somewhere , I just pull plug , drain caps , replug , sit 20m so caps will charge then power-up , if no reaction i just smack the machine and then it powersup. (eventually). - Unable to determine location , may be in the PSU(the issue).
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
There's a specific issue with the G5 tower having a tendency to fail due to solder problems on the lead-free machines; the ones with leaded solder never had an issue.
It's the chip with the massive heatsink that goes bad on these, but the best practice is to treat both as bad because one going out is not so great; the other one tends to go out next. However, this is a TEMPORARY SOLUTION and not permanent. For a longer-term solution, you will need to replace the motherboard and ASD; you can look online for it, but I'm not providing a link (COUGH Macintosh Repository COUGH) once you calibrate the processors AND replace the motherboard that fixes the problem.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
ediflorianUS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 13
