Can I take a hard drive from an iMac and boot from it on my MacBook Pr
Can I take a hard drive from an iMac and boot from it on my MacBook Pro to use the iMac as a portable computer?
Es esta una buena pregunta?
Can you explain your reason here a bit more.
Are you wanting to access the iMacs data from your MacBook Pro? Either locally or remotely.
Are you trying to setup your MacBookPro as a replacement of your iMac?
You don’t need to remove the drive from your iMac to attain that!
Fue útil esta respuesta?
Screen is destroyed and it’s a work computer and need to work in the interim
@bg234 - Which system has the damaged display? iMac or MacBook Pro and which model as that also effects the answer.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 23
