Saltar al contenido principal
Este es un controlador de pantalla táctil asociado con la consola de videojuegos Wii U. Fue lanzado el 18 de noviembre de 2012 y está disponible en blanco o negro. Número de modelo: WUP-010 (EE. UU.)
Preguntas 83 Ver todo
My wii u gamepad has water dammage and the buttons are not working
Some water spilt on my wii u gamepad and the following is happening (I let it dry for a day)
-The A button when pressed makes the same functions as the right bumper
-The LCD screen has water stuck inside
How can I fix it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Sounds like some pretty serious water damage. You’re going to have to replace the LCD at a minimum, and possibly the main board, since the issue with the buttons sounds like a blown fuse (or maybe the water is just mixing up signal paths). Try disassembling the game pad, and let all of the internals dry out, and keep an eye out for anything that looks burnt, or that looks like it exploded.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Water dammage came from when my parents got some people to clean the house and they accidently spilt something on it. I was out with my friends at the time so when I got home it was wet and then this happened
- de
@joelgunaratnam hmm, yeah, that would definitely cause water damage.
- de
@joelgunaratnam you want to treat this exactly like any other water immersed device.
For now you want to stop continuing to try to charge, sync or otherwise use your device. This potentially can make a bad situation worse.This may further damage your controller.
The very first step I would take is to disassemble your Gamepad. Use these guides Wii U GamePad to help you disassemble your device. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once you got the gross contamination (leftover water etc.) cleaned, use +90% isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your gamepad as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleanin. That can drive liquid, as well as corrosion particles into areas that will cause trouble later on. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned via an ultrasonic cleaner, but this will at least help. After that, reassemble your gamepad and re-evaluate. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
For as long as you have not cleaned your boards etc. everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
The water inside your LCD will evaporate, but it will most likely leave streaks etc. So there will be always be residual damage.
Puntuación 0
4 comentarios:
I replaced the battery. Right now I can't exactly open it up since I don't have a tri wing. I ordered one and I ordered a new LCD. I'll update once I do the cleaning and stuff
- de
@joelgunaratnam do not use it (turn it on etc.) until you can clean it.
- de
@oldturkey03 I'll make sure to, thanks for the help!
- de
@joelgunaratnam try a slightly larger screwdriver and use enough down force to loose the screws. If not, time for a Dremel like tool and to drill out the screws. Use a bit about half the diameter of the screw head. That will essentially remove the screw head. You can take the rest of the screws out with a pair of small pliers, after you opened it up.
- de
Añadir tu respuesta
joel gunaratnam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 62
