@vinkoaravena here are the options for your motherboard replacement
System board for use in models with discrete graphics equipped with the following processors:
Intel Core i7-8565U processor and 4 GB of GeForce MX250 discrete graphics memory L51994-xx1
Intel Core i7-8565U processor and 2 GB of GeForce MX130 discrete graphics memory L51993-xx1
Intel Core i5-8265U processor and 2 GB of GeForce MX130 discrete graphics memory L51992-xx1
Intel Core i5-8265U processor and 2 GB of GeForce GTX1050 discrete graphics memory L51991-xx1
Intel Core i3-7020U processor and 2 GB of GeForce MX110 discrete graphics memory L51990-xx1
System board for use in models with UMA graphics equipped with the following processors:
Intel Core i7-8565U processor L51987-xx1
Intel Core i5-8265U processor L51986-xx1
Intel Core i3-8145U processor L51985-xx1
Intel Core i3-7020U processor L51984-xx1
Intel Pentium N5000 processor L51988-xx1
Intel Celeron N4000 processor L51989-xx1
As you can see, it'll depend on whatever graphics chip your laptop supports. Do an online search based on those numbers
Have you checked your motherboard for any obvious damage. Checked for missing or burnt components.
Translation
@vinkoaravena aquí tienes las opciones para la sustitución de tu placa base
Placa base para uso en modelos con gráficos discretos equipados con los siguientes procesadores:
Procesador Intel Core i7-8565U y 4 GB de memoria para gráficos discretos GeForce MX250 L51994-xx1
Procesador Intel Core i7-8565U y 2 GB de memoria de gráficos discretos GeForce MX130 L51993-xx1
Procesador Intel Core i5-8265U y 2 GB de memoria de gráficos discretos GeForce MX130 L51992-xx1
Procesador Intel Core i5-8265U y 2 GB de memoria de gráficos discretos GeForce GTX1050 L51991-xx1
Procesador Intel Core i3-7020U y 2 GB de memoria de gráficos discretos GeForce MX110 L51990-xx1
Placa del sistema para uso en modelos con gráficos UMA equipados con los siguientes procesadores:
Procesador Intel Core i7-8565U L51987-xx1
Procesador Intel Core i5-8265U L51986-xx1
Procesador Intel Core i3-8145U L51985-xx1
Procesador Intel Core i3-7020U L51984-xx1
Procesador Intel Pentium N5000 L51988-xx1
Procesador Intel Celeron N4000 L51989-xx1
Como ves, dependerá del chip gráfico que soporte tu portátil. Haz una búsqueda en línea basada en esas cifras
¿Has comprobado si la placa base presenta daños evidentes? Comprobado si faltan componentes o están quemados.
Hola Vinko Aravena,
Es importante si puedes revisar como actúan los LEDS que indicas, (cantidad de veces que prenden y apagan o bien si solo están estáticos) si hay algún pitido del equipo al tratar de encender, ya que estos son códigos de error que determinan el problema que tiene el equipo (comunmente en esos casos, memoria RAM en falla, Motherboard dañada).
Ojalá puedas compartir esta información para poder darte una mejor ayuda y ver si es posible darte una solución.
Saludos.
- de Carlos Santoyo
