@richp25910 if there is even just a remote chance that this phone had any kind of liquid immersion, you will have to deal with that first.
The very first step to take, is to disassemble your phone. Use this video to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave your phone to dry for a day or anything like that. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate all the water.
The importance here is the cleaning. It would of course be best to get it professionally cleaned via an ultrasonic cleaner. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
After the cleaning, take a very close look (use a microscope) at your display connector.
Since you already tried multiple screens, without success, the issue is most likely a failed component in your display circuitry. This will require a board level repair. You will need some special tools and very good skills to do that type of repair.
You will need to check components and circuits like this.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@richp25910 si hay incluso sólo una remota posibilidad de que este teléfono tenía algún tipo de inmersión en líquido, tendrá que lidiar con eso primero.
El primer paso a tomar, es desmontar el teléfono. Utilice este video para ayudarle a desmontar el teléfono. Observe detenidamente todos los componentes y conectores. Evalúa realmente los daños. Busque corrosión importante, evalúe las clavijas de los conectores, etc. Eche un vistazo a todos los conectores, así como a los extremos de los cables. Usted tendrá que quitar todos los escudos EMI. Si no quita los blindajes, no está limpiando la placa. Una vez que haya limpiado la suciedad, utilice alcohol isopropílico al 90% y limpie las piezas un poco más. Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero sigue siendo pertinente para su teléfono también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza. No utilice aire comprimido para la limpieza, ya que puede conducir líquido, así como partículas de corrosión en las zonas que causarán problemas más adelante. No es necesario dejar secar el teléfono durante un día ni nada parecido. El alcohol isopropílico en la concentración más alta se evaporará rápidamente y disipará toda el agua.
Lo importante aquí es la limpieza. Por supuesto, lo mejor es que lo limpie un profesional con un limpiador ultrasónico. No olvide cambiar la batería. Esto es un deber y no una opción. Fallará si no te ocupas de ella ahora. Después, vuelve a montar el teléfono y evalúalo de nuevo. Mientras no hayas limpiado la placa y sustituido la batería, todo son suposiciones. Tenga en cuenta que los daños por agua son los más difíciles de localizar y reparar. No importa si se expuso durante 2 segundos o 2 horas, lo que importa es donde el agua (partículas) hizo el daño.
Después de la limpieza, eche un vistazo muy de cerca (use un microscopio) al conector de la pantalla.
Dado que ya ha intentado varias pantallas, sin éxito, el problema es más probable un componente defectuoso en el circuito de visualización. Esto requerirá una reparación a nivel de placa. Usted necesitará algunas herramientas especiales y muy buenas habilidades para hacer ese tipo de reparación.
Usted tendrá que comprobar los componentes y circuitos como este.
Mientras trabajas en tu teléfono, haz muchas fotos. Una vez que haya terminado con él, tomar esas fotos y crear una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://es.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
Reparar es hacer la guerra a la entropía
