Saltar al contenido principal
Dell Inspiron serie 3000 guías de servicio y referencia
Preguntas 20 Ver todo
newly keyboard not typing again
I recently changed my internal keyboard, it automatically types random keys without touching it, and many keys didn't even type correctly. And it happened again with my keyboard. how can I solve this problem?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios:
@ujjwalbhandari what happens when you connect a USB keyboard. Does it function correctly?
- de
Not external, I am talking about the internal keyboard. I recently changed and again same issue.
- de
@ujjwalbhandari yes, I understand. I just wanted to make sure that you tried a USB keyboard to see if that works.
- de
Agregar un comentario
2 Respuestas
Well you can do the following to fix the issue:
  1. Restart your computer.
  2. Check your keyboard connection.
  3. Make sure you have the correct text field selected.
  4. Disable sticky and filter keys.
  5. Try selecting a different text field.
  6. Clean the keyboard.
  7. Update your keyboard driver.
Fue útil esta respuesta?
Puntuación 0
Old Turkey asked "What happens when you connect a USB keyboard?" This is a troubleshooting step not implying that your problem is with an external kbd.
Since it has a mind of its own by inputting without user action, my guess would be a loose connection on a cable connector or a damaged cable. Any other problem is going to be economically prohibitive.
Puntuación 0
Añadir tu respuesta
Ujjwal Bhandari estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 46
