لماذا يرفض جهازي الاقلاع It does not charge or turn on
لا يشحن وايضا يرفض الاقلاع
Translation
It does not charge and also refuses to start.
Es esta una buena pregunta?
Translation
@nageebemad start of with checking your charger. Make sure it delivers the proper voltage. then check your charging cable. Make sure that it does not have any broken, bend or corroded pins. Next clean the charging port. Make sure it does not have lint or debris in it, no broken pins etc. You can clean it with a a few drops of isopropyl alcohol and a few puffs of compressed air. If all of that checks out, you need to replace the battery. While you do that, check the DC-In jack and make sure that it gets proper voltage on the board side.
Download the Maintenance Manual for your computer from here It will help you to work on your laptop. You will find vital information on all of this:
Power system checkout
To verify a power symptom, do the following:
1. Turn off the computer.
2. Remove the built-in battery.
3. Connect the ac power adapter. If the computer can be turned on, it means the ac power adapter is functional.
4. Turn off the computer.
5. Disconnect the ac power adapter and install the charged built-in battery.
6. Turn on the computer. If the computer can be turned on, it means that the built-in battery is functional.
If you suspect a power problem, see the appropriate one of the following power supply checkouts:
• “Checking the ac power adapter” on page 28
• “Checking the built-in battery and operational charging” on page 29
• “Checking the coin-cell battery” on page 29
You are here because the computer fails only when the ac power adapter is used.
• If the power problem occurs only when the docking station or the port replicator is used, replace the docking station or the port replicator.
• If the system status indicator does not blink three times when an ac power source is connected, check the power cord of the ac power adapter for correct continuity and installation.
• If the computer does not charge during operation, go to “Checking the built-in battery and operational charging” on page 29
Translation
@nageebemad تبدأ بفحص الشاحن الخاص بك. تأكد من توصيل الجهد المناسب. ثم تحقق من كابل الشحن الخاص بك. تأكد من عدم وجود أي دبابيس مكسورة أو منحنية أو متآكلة. بعد ذلك ، قم بتنظيف منفذ الشحن. تأكد من عدم احتوائه على نسالة أو حطام ، وعدم وجود دبابيس مكسورة وما إلى ذلك ، يمكنك تنظيفه ببضع قطرات من كحول الأيزوبروبيل وبضع نفث من الهواء المضغوط. إذا تم فحص كل ذلك ، فأنت بحاجة إلى استبدال البطارية. أثناء القيام بذلك ، تحقق من مقبس DC-In وتأكد من حصوله على الجهد المناسب على جانب اللوحة.
قم بتنزيل دليل الصيانة لجهاز الكمبيوتر الخاص بك من هنا وسيساعدك على العمل على الكمبيوتر المحمول الخاص بك. ستجد معلومات حيوية عن كل هذا:
الخروج من نظام الطاقة
للتحقق من أحد أعراض الطاقة ، قم بما يلي:
1. قم بإيقاف تشغيل الكمبيوتر.
2. قم بإزالة البطارية المدمجة.
3. قم بتوصيل محول التيار المتردد. إذا كان من الممكن تشغيل الكمبيوتر ، فهذا يعني أن محول طاقة التيار المتردد يعمل.
4. قم بإيقاف تشغيل الكمبيوتر.
5. افصل محول التيار المتردد وقم بتركيب البطارية المدمجة المشحونة.
6. قم بتشغيل الكمبيوتر. إذا كان من الممكن تشغيل الكمبيوتر ، فهذا يعني أن البطارية المدمجة تعمل.
إذا كنت تشك في وجود مشكلة في الطاقة ، فراجع أحد عمليات فحص مصدر الطاقة التالية:
• "فحص محول التيار المتردد" في الصفحة 28
• "فحص البطارية المدمجة والشحن التشغيلي" في الصفحة 29
• "فحص بطارية الخلية المعدنية" في الصفحة 29
أنت هنا لأن الكمبيوتر لا يعمل إلا عند استخدام محول طاقة التيار المتردد.
• في حالة حدوث مشكلة الطاقة فقط عند استخدام محطة الإرساء أو وحدة تكرار المنفذ ، فاستبدل ملف
محطة الإرساء أو مكرر المنفذ.
• إذا لم يومض مؤشر حالة النظام ثلاث مرات عند توصيل مصدر طاقة تيار متردد ، فتحقق من
سلك الطاقة لمحول التيار المتردد من أجل الاستمرارية والتركيب الصحيحين.
• إذا لم يتم شحن الكمبيوتر أثناء التشغيل ، فانتقل إلى "فحص البطارية المدمجة والتشغيل
الشحن "في الصفحة 29
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 78
