Saltar al contenido principal
El Dell Inspiron 15 3558, parte de la serie 3000, es un ordenador portátil de 15,6 pulgadas de reemplazo de escritorio con especificaciones sólidas, gran capacidad de almacenamiento y batería de larga duración.
Preguntas 6 Ver todo
Can’t find my Wi-Fi network, but sees others?
I went to use my laptop today but I noticed it shows all my neighbors Wi-Fi but not mine. It was working fine earlier today but now it doesn’t show it. When I boot into Linux it sees it but not Windows. My Wi-Fi is Eero Router.
How can I fix this without reinstalling Windows?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@stechkid
I believed is the Wifi 6 ax mode in your router causing older drivers not to show up, which I had experienced it before.
is your wifi model intel 7265?
https://www.thm.de/its/images/stories/An...
Some possible fix,
1. update router firmware to latest
3. Download latest wifi drivers from Dell website and install.
https://dl.dell.com/FOLDER05736979M/4/In...
3. alternative drop the wifi mode on your router to wifi 5 mode
Fue útil esta respuesta?
Puntuación 1
if it was working fine earlier today, then unless something updated or tried, it is a hardware problem. I have a router that doesn't transmit on one of the configurations. Fortunately, it has 3 Guest configurations and I switched it to another.
Puntuación 0
2 comentarios:
When booted into Linux it sees it fine and it can see my other networks so my laptop’s fine
- de
Hi @stechkid
Try just uninstalling the Wi-Fi driver in the Device Manger (devmgmt.msc) and let Windows reinstall it. This often fixes little problems.
- de
Añadir tu respuesta
80stechkid estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 15
Todo El Tiempo: 160
