Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Procesador i5 de doble núcleo A1418 / EMC 3068/2017 / 2.3 GHz. Lanzado en junio de 2017.
Can I swap internals from a stand iMac to a VESA-equipped iMac?
Had some issues upgrading my 2017 2.3 GHz Intel iMac, and it looks like I may need a new logic board. Can I pick up a functioning stand-equipped iMac of the same model and carefully swap in the logic board and maybe power supply board?
I would assume all the screw mounts and everything would line up but knowing Apple...
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Well… It’s not that simple here😞
The 2017 series was a transitional year! The 18.1 model is a carry over from the 2015 (1.6GHz 21.5" Late 2015) but still a bit different! Then we have the 18.2 models which have the 4K displays. So if you have the 18.1 as you’ve indicated here you don’t have a choice as it’s a 18.1 system and that’s it.
The reason you are limited is the older display uses a different interface than the newer 4K models. So the connections are not compatible internally.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
DayVess estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 28
Todo El Tiempo: 230
