Saltar al contenido principal
Modelo A1989, EMC 3358. Una actualización del diseño existente, con opciones de procesador actualizadas y un cambio en los materiales del teclado. Disponible en plata y gris espacial. Lanzado en mayo de 2019.
Preguntas 20 Ver todo
What happened? Is the Display flex cable damaged connecting LCD?
Hey guys and TIA for advice, my daughters 2019 mac 2.4 emc3358 was being used and she let her phone slip of her lap which slid along the keys and its corner bumped the edge panel, one inch to the left of where it says MacBook Pro. I am under the impression the LHS of the display flex cable would be in this area. It immediately lost screen image and it refuses to come back on. Apple said it was a sensitive area and want a lot to replace whole lcd screen assembly. Is it a hard fix?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I would guess that when the phone was dropped it had caused the ribbon cable to loose or come out. Should be an easy fix by seeing if the ribbon cable is misaligned or completely out of the socket. Try following this guide (Reemplazo de la pantalla de MacBook Pro 13" Touch Bar 2019) and in the process, check if there are any broken/disconnected cables. If a cable has simply disconnected, plug it back in. If a cable has broken, well..... you'll need a new display assembly.
Anchevauls Walker
@anchefixes
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thank you.
I will order the new lcd assembly. Can I ask why it’s not showing up on a seperate monitor? Also does apple not stop third party fixes with this T2 chip, I mean I thought it was designed to stop me swapping a new display assembly? Thanks again
- de
Añadir tu respuesta
OldMate69 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 378
