The Engine light is always turned on
My engine light is always turned on despite there is no issues with the engine, so how do I turn it off
Es esta una buena pregunta?
@pawanrai the engine light can be on for a multitude of reasons. I suggest you get the OBD2 scanned and see if and what code it shows. You can also reset the OBD2 with the scan tool.
If you know for sure that there are no issues with it, you can reset the light by removing the NEGATIVE battery cable. Remove it and keep it off for a few minutes. Then reconnect.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 21
Todo El Tiempo: 74
