How to unlock my audi with the keys inside.
I have recently locked by keys in the boot so ihave trie everything in power to unlock but to no avail. Please assist..
Es esta una buena pregunta?
If you can get into the passenger compartment, have you tried lowering the rear seat to reach in?
Fue útil esta respuesta?
The whole car is locked so i do not have access whatsoever. I was hoping to do this without any sort of damage to the car..
@richardmmatli - Sadly cars are getting harder to get in!
No second key? Did save the key ring the keys came with the car, there is often a small tag with a code. It allows you to order a replacement key. Some locksmiths have the blanks to cut the key if they have the code. Some newer keys have a electric element to prevent the ignition to function.
Tow operators sometimes can open a car so they can shift the car into neutral before they tow the car. Of course that only works in the city.
Maybe the local police can offer help. They of course know the car thefts! Maybe they can get one to help you (I know! Asking a thief for help does send the wrong message)
As an example my car only has a FOB which you click or I could program it to open the car as soon as I’m near the car. A newer version of keyless entry lets you use your phone.
I still have one key entry door but over time and lack of use it no longer works! One day my car battery will be dead at which point I’ll be like you on the wrong side of the coin too!
Sorry 😢
@richardmmatli it will depend on your location. The last thing you would want to try is to jimmy the door (unless you have experience). I have used AAA to unlock one of my vehicles before. There are also mobile locksmiths that offer unlock services. None of that is free but it's usually cheaper than to deal with any damage caused by forcing an entry.
Audi uses something called Advanced Key which allows the use of a cellphone app for entry etc. but that will have to be setup ahead of time. Unless you have done that already, it will not work for you now.
When I locked my keys in the car or when my dog locked me out of the car with my keys in it also the only way I could get in was with a hanger a stiff hanger and pressing the unlock button. That or a locksmith one of the ones with those things they put on the door that could just open it with their phone or whatever that's probably the least damaging way you can get in you can also if your windshield if your window is even just a little bit down you can pull that down enough to slide your hand in but it's not easy those are the ways I found the work
Ultimas 24 horas: 6
Ultimos 7 días: 14
Ultimos 30 días: 92
Todo El Tiempo: 2,830
