Weak WiFi Signal on Nokia G22
The WiFi signal on the Nokia G22 is very weak compared to other devices using the same hotspot. Have tested multiple WiFi networks and devices with the same result.
WiFi analyser app shows the Nokia with -65dBm signal, while a Motorola shows -54dBm.
Nokia support are useless and just keep telling me to reset and clear caches (done multiple times). Seems it is a design fault. Next step is sent it back for repair as they won't refund.
Any one else has this issue?
Es esta una buena pregunta?
Yes, I have this problem as well. My previous Nokia device managed to receive wireless in the weaker parts of our house, but not anymore. I've not checked the signal strength, but I'm almost continuously using 4G in certains parts of the house whereas with the previous phone this was not the case.
- de Liam Thompson
yes, I seem to be having wifi problems with android auto. I had to switch to 2.4 ghz, that may have improved the situation, but its not an optimal solution. I still possibly have problems with the wifi signal even on 2.4, I will have to verify
- de Eli R
It keeps disconnecting, it's absurd, I can't surf the internet or even chat smoothly because I have to go to the settings. The same problem exists also for the cellular signal which is very weak and I have to go and send messages near the window if I'm indoors. It's ridiculous, an incredible and unexpected disappointment from Nokia.
- de Domenico Daniele
my device cannot acces wifi
- de Fortunatus olomi
