Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1525 Ver todo
Building my old iPhone
I have two iPhones, one is my old iPhone 6 Plus which won’t turn on anymore and the other iPhone is an iPhone 6 Plus I bought listed on eBay as parts only. Now my question is this, when rebuilding my iPhone does anyone know what parts from the old iPhone I need to use and transfer to the new rebuild in order to ensure it’s rebuilt and will turn on with all the old phones information as if nothing ever happened to it?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @missbritt486,
To answer your specific question, the only parts you absolutely need from your old phone are the logic board (AKA the motherboard) and the home button. The home button is paired to the motherboard for the Touch ID function, so if you want that to work you have to use the one that's paired to the board, otherwise you'll permanently lose Touch ID, as only Apple can restore that function.
With any luck swapping those two parts into your parts phone may get you working again, but that's based on the assumption that it's something other than the motherboard that's causing your phone not to turn on. I'd say the chances are fairly good that it could work in the new chassis, but be prepared for the possibility that it might not.
You'll need to follow these two guides in order to change out the needed parts.
iPhone 6 Plus Logic Board Replacement - iFixit Repair Guide
iPhone 6 Plus Home Button Assembly Replacement - iFixit Repair Guide
Don't forget to pick up a sheet of precut adhesive to glue the screen back on and help keep liquids out.
I'd suggest starting with the logic board and doing that replacement first, that way if it doesn't work it'll save you the trouble of swapping the home button for no reason. Hook the screen back up then plug in the battery. Fold the screen back over the chassis but you don't need to clip it in place, just try turning the phone on and see if it works. If it does, you can try swapping over the entire screen assembly from your original phone; if the screen is good then your work will basically be done and you won't have to change the home button after all; just use the whole screen that has the original button.
If, on the other hand, the new screen works but the old one doesn't, then you'll have to swap over the home button to the new screen. Just be careful with it; if you damage it you won't be able to replace it and have the Touch ID work again.
Good luck; get that logic board moved over and let us know what happens when you get it installed!
Update (05/31/23)
Note that I'm writing this with the assumption that the eBay phone you bought is fully functional but (most likely) iCloud locked, which is exactly what I would have done in your case.
Imagen de iPhone 6 Plus Ensamblaje del botón de Inicio
Guía
Reemplazo y ensamblaje del botón de inicio de iPhone 6 Plus
Dificultad:
Moderado
30 minutes - 1 hour
Imagen de iPhone 6 Plus Logic Board
Guía
Dificultad:
Moderado
40 minutes - 2 hours
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Missbritt486 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 32
