Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
Versión más pequeña del iPad Pro original. Lanzado el 31 de marzo de 2016. Cuenta con una pantalla de 9.7", procesador A9X y opciones de almacenamiento de 32/128/256 GB. Disponible en plata, gris espacial, oro y oro rosa.
iPad screen issue after battery replacement
I replaced the battery of my iPad pro 9,7 inch (2017). After reconnecting the screen, I turned on my iPad and found the screen not working (please refer to the attached picture). Any idea on what causes this issue? The screen connectors on the logic board and the ribbon cable do not seem damaged, so I am wondering if a replacement screen should fix the issue. Could I maybe have damaged the screen whilst removing it from the iPad?
Imagen
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Looks like you've damaged it. New screen unfortunately. Not cheap either.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Yeah I think so too. But in the end with the new screen its probably going to be less expensive or similar the amount I would have to pay a shop to do a battery replacement. I decided to try it because it's an older device anyways and I got to learn something out of it. Better luck next time!
- de Compartir
Battery replacement is a lot cheaper than a replacement screen on a ipad pro unless the shop you go to is a rip off merchant.
- de Compartir
Añadir tu respuesta
Patches90 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 590
