Saltar al contenido principal
El Google Pixel 7a es la variante económica de la serie Pixel 7. Lanzado en mayo de 2023, el Pixel 7a mejora el Pixel 6a con desbloqueo facial, 8 GB de RAM, cámaras muy mejoradas y carga inalámbrica.
Preguntas 11 Ver todo
Glass cracked but screen is working fine.
So my new pixel 7A fall from scooter mount stand and it's glass was shattered from top left part but the screen is still working perfectly and so is indisplay finger print scanner.
The only thing I noticed is that the front camera is showing bit white shade in it's view finder maybe due to visible crack lines infront of it
I want to know what are my options now? Do I need to replace whole display or is it possible to replace front glass only.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi Bil,
In theory yes, the front glass can be replaced. However, in order to do it correctly, the process requires a vacuum chamber to remove air bubbles from between the front glass and the OLED and a UV chamber to cure the Optically Clear Adhesive (OCA) glue that's used to bond them together.
That assumes you can separate the original glass from the OLED without damage. Even experienced technicians can't guarantee 100% success doing this, and to be honest your chances of success on your first try aren't good. You need a vacuum table to hold down the display and a set of wire guides on each side to hold the thin wire at the right height to cut the adhesive without damaging the screen.
So yeah, vacuum table, wire guides, vacuum chamber and UV chamber; I don't know about you but I don't happen to have any of those lying around my garage.
The upshot is that I wouldn't recommend glass replacement. You can probably accomplish a half-assed version of that repair without the equipment, but figure it's going to look like a badly applied screen protector when you're done. Buying a full screen assembly will give you much better odds of success. Given how new it is, there aren't any screen replacement guides available yet, but I did run across a teardown video. If you compare that to something like a Pixel 7 screen replacement guide, you should be able to figure out what needs to be done.
Google Pixel 7a Teardown Disassembly Repair Video Review - YouTube
Although iFixit sells genuine Google Pixel parts, the 7a is too new so you'll have to look to other suppliers. I see a few being offered on eBay such as this one.
For Google Pixel 7a LCD Display Touch Screen Digitizer GWKK3 GHL1X G0DZQ G82U8
I did run across sites online offering glass replacement, so that might be an option for you, but you'll have to locate a service yourself.
Of course, as a last resort you can always have Google do the repair, but no idea what it's going to cost you.
Good luck and let us know what you find!
Fue útil esta respuesta?
Puntuación 3
if you follow the videos that are on You tube you're on the right path.
Puntuación 0
Añadir tu respuesta
Bil estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 27
Ultimos 30 días: 206
Todo El Tiempo: 2,315
