Why does my heating shield make noise
It makes a rattle noise from heating shield , every time I accelerate car
Es esta una buena pregunta?
One or more fasteners are loose or missing. Another possibility is the heat shield is bent reducing the clearance require to prevent a rattle. this should be a quick and easy repair that will cost you less than $100. A third possibility is a broken exhaust hanger that allows the exhaust system to move far enough to contact the heat shield. One more possibility is a broken or wore out engine mount. If engine movement is excessive that may allow the exhaust to contact the heat shield.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 79
Be more specific, what Fit what specs what noise.
- de Tom Chai
