What size star tip does the front break caliper take
What size star bolt is the front calipers mounted with?
Es esta una buena pregunta?
@scottturne66536 those are Torx T55. Those are a bear to take off, so you want to make sure that you use a cheater bar as well. You do not need to take those off, if you just want to change your brake pads etc. For that, you just remove the two 18mm bolts to remove the caliper bracket. Just saying....:-)
Fue útil esta respuesta?
Ultimas 24 horas: 7
Ultimos 7 días: 40
Ultimos 30 días: 153
Todo El Tiempo: 1,063
