Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Interior lights don't work
Interior lights and button to lock the doors don't seem to work. I just bought this car second hand. However Window buttons do work. Also button to open trunk doesn't not work. Any suggestions?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
4 comentarios:
@corneliousj5992 What model year is the car?
- de
Hi Andrew it's a 2004
- de
@corneliousj5992 Have you checked that the fuses are all good?
- de
No, I'm not sure how to check or which one to look for.
- de
Agregar un comentario
2 Respuestas
  1. Check fuses (Info at the cover of the fuse box) or just replace the broken one ;-)
  2. Check the door sensor if it recognizes door(s) state (open/closed). maybe disassembly is nessesary
  3. Check button and interior lights by measure powersuply if car is started or key is in pre-ignition position
  4. If VCDS diag system is available. You can check for erros in one of the control units
additional infos, schematics, exploding drawnigs can be gained via erWin of AUDI - erwin.audi.com
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thanks! I'll give it a shot!
- de
нужно осмотреть блок предохранителей,и под ковром,со стороны водителя есть блок комфорта ,если во время езды из дна машины выпала заглушка,то вода могла попасть внутырь и намочить сам блок. а он отвечает за множество функций ,центральный замок,освещение салона,настройка длительности освещения.
Puntuación 0
Añadir tu respuesta
Cornelious Jordan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 36
Todo El Tiempo: 693
