blows fuse when trying to crank
When I try and crank the engine the 40 amp fuse for the crank blows immediately
Es esta una buena pregunta?
You have a short circuit. Disconnect the solenoid wire for the starter and try cranking again. Of course the engine will not crank but if the fuse does not blow then you need a new solenoid. If the fuse still blows the short is in the wiring. Inspect and repair as required.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 27
