Saltar al contenido principal
El reloj inteligente de quinta generación de Apple, con conectividad celular opcional, lanzado el 20 de septiembre de 2019.
Best Non OEM Replacement Screen?
Subject is an Apple Series 5, 40 MM watch with a cracked screen. I can still see the icons.
Do I need anything more than a replacement screen kit to fix this?
There are multiple screen kits available ranging from $10 to over $200. Which is the best bang for the buck. It doesn't make sense to buy a $139 screen kit for a watch that old.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
3 comentarios:
you should link the one you're interested in so we can take a look at it.
- de
Looking at this one Apple 5-40mm
- de
@stanleybunch this isn't a full display, its only the digitizer and front glass, so if you have LCD problems, or problems with the backlight, this won't fix it unfortunately :(
- de
Agregar un comentario
2 Respuestas
@stanleybunch - That link is only the crystal/digitizer part it’s not the OLED panel part which is glued to the crystal/digitizer part. That’s why it’s so cheap (note they called it an LCD which it’s not)
I really don’t recommend attempting ungluing the OLED as more often than not you just end up killing it. It’s better to get the full assembly.
Fue útil esta respuesta?
Puntuación 0
Buy a complete screen assembly, they aren't cheap. If you don't want to spend a lot then I'd bang it on ebay as spares or repairs and let someone else have a go. OR, look on ebay for the same watch locked to icloud and use the screen off it.
Puntuación 0
Añadir tu respuesta
Stanley Bunch estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 37
Todo El Tiempo: 522
