Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El ordenador portátil HP Pavilion G60-630US se fabricó en 2010 y funciona con un procesador Intel Pentium de dos núcleos T4400 de 2,2 GHz. El portátil tiene una carcasa exterior negra con un interior plateado.
When I upgrade my Ram and HDD to SSD, what will be the best compatible
Hello, When i upgrade my Ram and HDD to SSD, what will be the best compatible to it, because I want to restore this laptop to be better. Thank you for the big help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
You maybe over reaching here. What is your workflow?
Like a lot of things things change with time and a 2010 system can only go so far in what it can offer. The first one is the graphics this series offered can’t support the newer OS’s as well as applications they use them.
That’s not to say the system can’t still be used as is, it’s just the investment of upgrading it need to be thought-out a bit as you may not gain anything and your expectations maybe a bit too high.
Fue útil esta respuesta?
Puntuación 0
@abigailbongala Download the maintenance and service guide for your laptop from here It’ll help you with the upgrades. With your G60 you are limited to a maximum memory capacity of 4 GB of DDR2 PC2-6400 800 MHz SODIMM memory. Looks like you can also upgrade the processor on this model. Recommended for better performance is a T9400 Socket P. For the How-to on that upgrade, take a look on here. For the SSD upgrade, get something like this That particular seller is in the UK but you can get the drives pretty much anywhere. It's just to show you the options for your laptop. All of this will improve the performance of your laptop. No, it’s not going to be the latest and greatest. But it’ll be a solid performer.
Puntuación 0
Añadir tu respuesta
Abigail Bongala estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 300
