Where is the CMOS Battery located on this board?
Hi there,
I've been having an issue recently where the laptop will suddenly shut off after a couple of minutes. The laptop when reconnected to power will then turn on with a black screen and will eventually display a CMOS reset on the display before booting into windows again. The board is stuck in some sort of loop and I was hoping a new CMOS battery would fix the issue.
I opened the laptop and couldn't locate the CMOS battery on the motherboard of the laptop. I presume the CMOS battery is embedded inside the main battery but I've replaced the battery and the issue still persists. Please reach out!
Es esta una buena pregunta?
Can you confirm that exact model of the laptop? I suspect you are correct with regard to the CMOS battery being tied to the main battery, but there are so many variants of some of these PCs I always want to confirm.
- de Alisha C
@flannelist The model I believe to be the 15-cx0000 version.
- de Millerbes
