Saltar al contenido principal
Un cepillo de dientes electrónico fabricado por Philips y lanzado en 2007. Cinco modos diferentes, diseñados para limpiar los dientes de forma más eficiente.
Preguntas 6 Ver todo
Beeping, one long, two short
My trusty Sonicare has started beeping in a repeating pattern while charging. It still works, but only occasionally. Is this fixable or do I need to buy a new one? It is by far the best toothbrush I have ever had, so I don't want to just discard it without attempting a fix or knowing I need a new one.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
1 comentario
Mine only works for about 2 seconds and stops
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Try this fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove the brush head.
2) use a screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of the base handle. allow it to air dry
5) allow the switch to air dry
6) reassemble
Fue útil esta respuesta?
Puntuación 3
8 comentarios:
my sonicare doesn't have a silver button, only a green one. And no screwdriver has been able to turn the base 1/4 turn. Any other ideas?
- de
Mine also does not have a silver button. I think it depends on the model. I just held down the power button while the brush was on the charging base, per Hayden's instructions above. It responded with a series of vibration signals, then the beeping series stopped "like magic." So far, so good.
- de
None of the above works
- de
None of the suggestions work. Tge beeping is driving me crazy.
- de
None of the suggestions work. The beeping is driving me crazy.
- de
Mostrar 3 comentarios más
Had the same issue. From what I can tell, it was telling me the toothbrush was still on while it was charging. (The battery died mid-brush.) I turned it off while on the base (don’t know if that matters) and the beeping and flashing lights stopped. Hope this helps.
Puntuación 0
Añadir tu respuesta
Don H Smith estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 34
Ultimos 7 días: 337
Ultimos 30 días: 1,523
Todo El Tiempo: 33,425
