How to remove the needle
How do I replace the needle. My model had a plastic needle protector with no screw. How do I remove this?
Es esta una buena pregunta?
hello Shauna
To remove the needle from the Singer EZ-Stitch Chainstitch Sewing Machine, follow these steps:
To replace the needle on the Singer EZ-Stitch Chainstitch Sewing Machine, follow these steps:
If your model has a plastic needle protector with no screw, you can remove it by gently pulling it straight out from the machine. Once the protector is removed, you can follow the above steps to replace or remove the needle as needed.
or
you can refer to this video
link:- https://youtu.be/K11bofV8Ov0
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 79
