Won't charge or turn on
My tablet won't charge or turn on what's the best thing to look at first
Es esta una buena pregunta?
If it won't charge check the charger or charger cable (try using different, compatible, known working ones) and if they're OK, use a magnifying glass and a strong light to visually inspect the charge port in the tablet.
Check that there's no lint or other debris in the port enclosure that may be preventing a good electrical connection and also that all the pins are there, and that they're straight and parallel and not bent etc,
If there is any debris in the port enclosure, do not use a pin or metal probe to try and clear it. Try using a vacuum cleaner and check if that removes it.
If all the above seem OK the tablet will have to be opened and tested to find out what's wrong.
Here's the ifixit Samsung Galaxy Note 10.1 2012 guide that may help.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 57
