Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
2.3L 4cil o 3.0L V6, 6ª generación
Cranks but won't start
2000 Honda Accord 2.3 cranks but won't start. I have replaced all the common issues ignition switch, ignition coil, etc. It is getting fuel has compression but the spark seems very weak. Tested the voltage to the coil and it is 3.3 volts. Any suggestions on where to go next?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
The voltage from the coil seems low. Not much experience with Hondas though. Is that the output voltage or what's coming into it?
Fue útil esta respuesta?
Puntuación 0
1 comentario:
That is voltage to the coil
- de
if you haven't done this yet, check your eng, fuse. my car would crank but not start & that was it. it's a 10amp
just now by will
Puntuación 0
Añadir tu respuesta
Michael Leonard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 670
