Saltar al contenido principal
La Nintendo 3DS XL 2015, comercializada como New Nintendo 3DS XL, se lanzó el 11 de octubre de 2014 en Japón y el 13 de febrero de 2015 en Norteamérica.
Broken ZIF connectors. How do I fix them?
I recently tried taking apart my New 3DS XL only to find out that I'm an absolute idiot. I broke several of the FPC ZIF connectors by lifting them up. My 3DS no longer turns on completely, but instead the power light stays on for maybe three seconds only for it to make an extremely quiet pop and immediately the light turns off. I don't know if the connectors are the reason it no longer turns on correctly, but I would guess so since everything else seemed fine (no obvious torn ribbon cables or partially connected cables).
I would like to know how to repair the connectors. Can I use glue or something to keep the parts I lifted up down? Or should I try my hand at soldering?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
I don’t know that I have seen these specific ZIF connectors before, but I always dislike ones that hold the cable in with just friction. It is SO easy to do this exact thing.
In a perfect world, I would say replace the connectors. But that presumes soldering experience. And ability to find new connectors. It would be doable without a ton of soldering know how (in my opinion), but they are super prone to melting, so they take some finesse to do properly .
In the absence of your ability to do that, you can attempt to repair these so they are solid enough to hold in the cable. Some good tape may be enough to keep it in place. It’s not a very elegant solution, but it may do the job. Otherwise, you can try to glue them together, but that’s a pretty precision job. I am sure there are better things for this, but I have used superglue and baking soda mixed together for stuff like this in other cases. Just never on anything that small. But mixed together it cures very quickly (it’s a matter of seconds when it goes). And it’s quite strong.
Fue útil esta respuesta?
Puntuación 4
2 comentarios:
Used the baking sodaand super glue.... it worked !
- de
My connector has fell off and snapped in two I've tried taping the ribbon down to the pads but won't stay on unless I press down. Do you just put super glue on the contacts and push it down and hope it's lined up really need help
- de
could be bent, go ahead and buy those parts!
Puntuación 0
Añadir tu respuesta
[deleted] estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 45
Ultimos 30 días: 213
Todo El Tiempo: 3,402
