Saltar al contenido principal
Disponible desde Mayo del 2020, El MacBook Pro 13" incorpora un procesador quad-core Intel de 8ª generación Core i5 e i7, y una gráfica integrada Intel Iris Plus 645. (Modelo A2289/EMC3456 con dos puertos Thunderbolt 3)
Preguntas 20 Ver todo
The System cannot be restored on this device. Failed to restore device
Failed to restore device in recovery mode, libusbrestore error: 2012 [com.apple. MobileDevice. MobileRestore
- Ox7DC (2012)|
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
Hi! Have you sucseeded solving the problem? I've spent couple of days trying to fix MacBook Pro 2018, it got worse and worse, no options, same Ox7DC (2012) DFU error.
- de
Agregar un comentario
1 Respuesta
You need to fully wipe the drive, but to do that you need to boot from an external drive to then run Disk Utility from that externals files.
You have a bit of a Towers of Hanoi problem
You need access to a second Mac otherwise or if the internet recovery is working you can build the external drive but Apple doesn’t make it easy! As the recovery will be the original macOS not what you are running today.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
I have tried restoring with 2nd Mac Book. But that’s the message, which keeps popping up. Any other methods.?
- de
@yayavat48 - Did you do a full reformat of the drive and only install a fresh OS from the Apple OS installer?
- de
Añadir tu respuesta
yayavat48 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 34
Todo El Tiempo: 2,395
