Why is my phone in a reboot loop
The phone will restart over and over again. Sometimes I can't even turn the phone on.
Es esta una buena pregunta?
you need to restore/recover android on your LG
i found a guide that will walk you through how to do this for your model
Fue útil esta respuesta?
Common issue on this model (on many LG phones in general. The memory chip lose contact with mainboard, permanent fix is reball the chip. Temporary solution is heat up the phone with hair dryer on cca 60°C, the metal contact will lettle bit expand and Temporary will be there electric contact. I recomend this solution only for turn on the phone and také important data. There is no way to fix with any software becouse is hardware problem.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 148
