The batteries corroded in the camera . How do I successfully clean th
How do I clean the inside battery compartment? The batteries corroded . I removed the bad batteries and need to clean the connectors
Es esta una buena pregunta?
I’m assuming the leaking battery didn’t get into the body of the camera. If it did, you’ll want to open the body and clean it out using the same method below except DON’T use a screwdriver to get the corrosion off. Stick with a plastic brush. For the battery compartment:
Hope this helps to save that camera.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 99
