Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Airport Time Capsule es un enrutador inalámbrico y un dispositivo de almacenamiento conectado a red (NAS) fabricado por Apple. El modelo A1409 es la cuarta generación de la Time Capsule, lanzada en junio de 2011.
Replace airport card/modem in TC gen 4 (802.11N)
Can I replace the Airport Card/Module in the Airport Time Capsule A1409 4th gen (802.11N)?
I fear the answer is Duh, NO!, but the answer is always no if you don't ask.
Thanks, Mark
PS: Is it worth replacing the HD with a SSD?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
While you can’t alter the capsules WiFi interface, you can still connect a WiFI unit externally! As far as swapping out the HDD to a SSD while that can be done, you won’t get the best performance as this units SATA interface is only SATA II not SATA III
So consider your needs, review your cost Vs benefits.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thank you. Cost is a biggie, but having pieces parts lying around, had to ask those with more experience, skills and knowledge than me.
It works well, as a basic backup, but occasionally I get the Tim "The Toolman" Taylor moments, and want to make it faster, better just because it's (sometimes) possible. ; )
- de
Añadir tu respuesta
mark ray estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 30
Todo El Tiempo: 246
