@hugosanche97108 what you are experiencing is liquid damage. For now you want to stop continuing to try to charge, sync or otherwise use your computer. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your Sony using something like this video as a guide. Remove your motherboard. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors (pay particular attention to your LCD connector and cable) and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your device. While you clean your board, check for any obvious damage, like burned or missing components etc. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your computer and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Translation
@hugosanche97108 o que está a experimentar são danos líquidos. Por agora, quer parar de continuar a tentar carregar, sincronizar ou utilizar o seu computador. Isto pode potencialmente agravar uma má situação, o que pode danificar ainda mais o seu telefone.
A próxima coisa a fazer é limpá-lo. Desmonte o seu Sony usando algo como este vídeo como guia. Remova a sua placa-mãe. Deve remover todos os escudos de EMI. Se não os remover, pode muito bem não fazer nada. Depois de os remover, limpe toda a placa, conectores (preste especial atenção ao conector e cabo LCD) e tudo com +90% de álcool isopropílico. Siga [guia|5825|este guia] , e mesmo assim foi escrito para um 3G todos os pontos continuam a ser pertinentes ao seu dispositivo. Enquanto limpa a sua placa, verifique se há algum dano óbvio, como componentes queimados ou em falta, etc. Todos estes passos são para evitar falhas retardadas causadas pela corrosão. O melhor a fazer seria limpá-la com um produto de limpeza ultra-sónico, mas se não tiver acesso a um, isto irá pelo menos ajudar. Uma vez tudo isto feito, remonte o seu computador e reavalie-o. Até que seja limpo, tudo será apenas um palpite. É possível que tenha um mau LCD e a substituição da montagem do visor pode consertá-lo. Mesmo com tudo isto, os danos causados pela água têm apenas uma pequena hipótese de serem totalmente reparados, mas pelo menos pode tentar.
