Is there a fuse there?
Where is located the fuse and how can I approach it?
Es esta una buena pregunta?
Try the following methods to restore power to the Brother machine:
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
Fue útil esta respuesta?
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 29
Todo El Tiempo: 329
There are numerous fuses. Can you describe the symptoms?
- de Jim
The printer does not show any sign of life after an unclear power interruption.
- de tvarozna
