Por que se le fue agua al celular
Metí mi celular en una piscina por menos de 3 minutos y se le fue agua, luego se le puso la pantalla en morado y posteriormente en color negro
Es esta una buena pregunta?
@diegomonroe yes, your phone is water damaged. For now you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using something like this video as a guide . You must remove all EMI shields from the circuit board. If you do not remove those, you might as well not do anything. After you remove those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://es.ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@diegomonroe sí, su teléfono está dañado por el agua. Por ahora es mejor que dejes de intentar cargarlo, sincronizarlo o utilizarlo. Esto potencialmente puede empeorar una mala situación.Esto puede dañar aún más su teléfono.
Lo siguiente que debes hacer es limpiarlo. Desmonte su teléfono usando algo como este video como guía . Debe quitar todos los escudos EMI de la placa de circuito. Si no los quita, es mejor que no haga nada. Después de quitarlos, limpie toda la placa, conectores y todo con +90% de alcohol isopropílico. Sigue this guide , y aunque fue escrita para un Apple iPhone 3G todos los puntos son pertinentes para tu teléfono. Mientras limpias la placa, comprueba que no haya daños evidentes, como componentes quemados o que falten, etc. Cuando esté bien limpia, sustituye la batería. Todos estos pasos son para evitar el fallo retardado causado por la corrosión. Lo mejor sería limpiarla con un limpiador ultrasónico, pero si no tienes acceso a uno, esto al menos te ayudará. Una vez hecho esto, vuelva a montar el teléfono y evalúelo de nuevo. Hasta que no se limpie, todo serán suposiciones. Es posible que tenga una pantalla LCD defectuosa y que la sustitución del conjunto de la pantalla pueda solucionarlo. Incluso con todo esto, los daños por agua sólo tienen una pequeña posibilidad de repararse por completo, pero al menos puedes intentarlo.
Mientras trabajas con el teléfono, haz muchas fotos. Una vez que hayas terminado, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://es.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 31
