Como arreglar mi celular que no quiere cargar porque le entro agua
Como puedo arreglar mi celular que le entro agua y ya no quiere cargar
Es esta una buena pregunta?
ponlo en un cargador inalambrico , si carga entonces solo se daño el puerto de carga , deberas cambiarlo o solo utilizar un cargador inalambrico
Fue útil esta respuesta?
@jesusdanie41083 for now you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it.
The very first step I would take is to disassemble your phone. Use something like this video to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned with an ultrasonic cleaner. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. You might want to consider replacing the charging board (daughter board). since that may have gotten damaged and thus your phone no longer charges. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@jesusdanie41083 por ahora usted quiere dejar de seguir tratando de cargar, sincronizar o utilizar el teléfono. Esto potencialmente puede empeorar una mala situación.Esto puede dañar aún más su teléfono.
Lo siguiente que hay que hacer es limpiarlo.
El primer paso que yo daría es desmontar el teléfono. Utilice algo como este video para ayudarle a desmontar el teléfono. Observe detenidamente todos los componentes y conectores. Realmente evaluar los daños. Busque corrosión importante, evalúe las clavijas de los conectores, etc. Eche un vistazo a todos los conectores, así como a los extremos de los cables. Usted tendrá que quitar todos los escudos EMI. Si no quita los escudos, no está limpiando la placa. Una vez que haya limpiado la suciedad, utilice alcohol isopropílico al 90% y limpie las piezas un poco más. Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero sigue siendo pertinente para su teléfono también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza. No utilice aire comprimido para la limpieza, ya que puede conducir líquido, así como partículas de corrosión en las zonas que causarán problemas más adelante. Tampoco es necesario dejar secar durante un día. El alcohol isopropílico en mayor concentración se evaporará rápidamente y disipará el agua. Lo importante aquí es la limpieza. Por supuesto, lo mejor es que lo limpie un profesional con un limpiador ultrasónico.
No olvide cambiar la batería. Es una obligación y no una opción. Fallará si no te ocupas de ella ahora. Después de eso, vuelva a montar el teléfono y vuelva a evaluar. Es posible que desee considerar la sustitución de la tarjeta de carga (tarjeta hija). ya que puede haber sido dañado y por lo tanto su teléfono ya no se carga. Mientras no hayas limpiado la placa y sustituido la batería, todo son suposiciones. Tenga en cuenta que los daños por agua son los más difíciles de localizar y reparar. No importa si se expuso durante 2 segundos o 2 horas, lo que importa es donde el agua (partículas) hizo el daño.
redmi9A volumen bajo
Se descarga muy rápido
Por favor Emilio no escribas un telegrama, detalla que terminal es que le pasa exactamente, ¿Cuanto es se descarga muy rapido? y cuanto hace que no se cambia la bateria
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 178
