Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
A1418 / EMC 3068 / iMac 18,1 / procesador i5 de dos-núcleos a 2.3 GHz. Lanzado en junio de 2017.
No display and no chime.
2017 iMac with display issues and no chime at boot.
1st 3 LED’s light up but the 4th LED will not light up and external display does not work either.
If the cables for the monitor are attached fan moves slowly. If I disconnect the cables and turn it on fan blows at full speed.
Is this a display issue or a logic board issue?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
The fan is likely working correctly here. SMC controls the fan based on thermal sensors, so when you disconnected the display cable SMC went into CPU Safe Mode which will push the fans RPM.
With that said this series uses the integrated Intel graphics engine within the CPU. Sadly that part of the package failed. You need a new logic board.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you very much for the reply!
- de
Añadir tu respuesta
Infinus estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 303
