replaced logic board now can only boot in safe mode
After fixing the infamous ATI chip problem a couple of times using the heatgun technique, I finally managed to fry my 2.16GHz logic board...so, after some research I decided to buy a new logic board just to give my laptop some more life...I eventually went for a 2.33GHz board as it's a direct replacement on A1211 models and also because it was the only one I could find at a reasonable price.
Everything went ok, except that I can now only boot in safe mode...a normal boot get stuck on the grey screen and I can't seem to be able to boot from the Snow Leopard disc either...
Anyone has some suggestions/advice on how to fix that?
Es esta una buena pregunta?
4 comentarios
Did you try a power manager reset (SMC) and a PRAM reset ? After a logic board replacement the board could need a reset to work as it should.
- de lemerise
Are you using the gray install disks or retail 10.6 disk?
- de mayer
SMC and PRAM reset...no luck...and I'm using a 10.6 retail disk...next thing I'll try: target disk mode - FW cable to another Mac and run Disk Warrior...don't know what else to try...pretty sure it's a software issue...
- de Fabio
I had this problem, but it was still the video card that was bad. Booting normal it it would hang on a light blue screen just before your wall paper appears.
Booting from disk wouldn't work other.
- de Rav4Baby
