Saltar al contenido principal
La primera generación del coupé deportivo compacto, el Scion tC.
Preguntas 6 Ver todo
When I stop on the light idle going down but not stay jupm to 1200rpm
Hi I have a problem with my Scion tc 2006 .Onlny When I stop on the light idle going down but not stay and jupm to 1200rpm ,theb they fall back and stay in normal place . I"ve tred everything already.Clean throttle body new throttle body ,reset ECM 1000times .the problem was permanenet . Computer it doesn't show errors.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Kazik,
Reading up on this over at the Scion forums, it appears you have a lot of company with this particular problem. The majority of posters are of the opinion that it's just the ECU adjusting itself, and thus normal behavior. Others aren't so sure, with explanations including the engine temperature sensor, mass airflow sensor, idle air control valve, coolant level, oxygen sensors and vacuum leaks. They pretty much all agree that there's no trouble codes showing. They've also mentioned the throttle body, but since you've replaced it, we can scratch that one off the list.
I'd say start with the mass airflow sensor (MAF) since it's easy to test. Just unplug it and drive the car normally. With the MAF disconnected, the car will default to preset values for the airflow based on other factors such as throttle position, so if the MAF is giving bad readings they'll go away when it's unplugged. If it stops doing the idle thing with the MAF disconnected, then it's a fair bet you should replace the airflow sensor.
Other than that, about all you can do is work your way through the list trying to eliminate as many sources of trouble as possible. If you've got access to an OBD-II scanner that can show live data, you can check the oxygen sensors while it's running, plus a lot of other things like the engine temperature.
Nothing definitive here, but hopefully you've got some things to check now and thus a place to start. Good luck; let us know what you find!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Kazik Kazik estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 97
