El portátil no enciende
Hola El Portatil no enciende, carga y suena el ventilador pero no enciende como se podría arreglar?
Es esta una buena pregunta?
Hola Isabel
Con un monitor externo da el mismo problema?
Con esto podrías descartar que fuera un problema del mismo monitor. Ya que si no es este el problema, hay muchas opciones de que sea un problema de placa base, que no se puede reparar sin herramientas y conocimientos especializados.
Un saludo
Fue útil esta respuesta?
Isabel teresa Rodríguez besides the great answer given by my colleague @oscarsp I would like to propose that you check a few things.
First I would try the standard Apple SMC and PRAM reset
Resetting the System Management Controller (SMC)
To reset power management via the SMC chip:
1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
2. Connect the power adapter to the computer and to a working power source.
3. Important: Use the keys on the left side of the keyboard. On the built-in keyboard, press Shift-Control-Option along with the power button once.
Note: When the LED on the MagSafe connector is orange, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset.
4. Wait 5 seconds and press the power button to restart the computer. Note: If bottom case is removed, you may alternately reset the SMC by disconnecting the power adapter and the main battery, and holding the power button down for five seconds.
Resetting the Parameter RAM (PRAM)
To reset PRAM,
1. If the computer is on, turn it off.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in Step 4.
Note: If the keyboard does not have an Option key, use the Alt key instead.
3. Turn on the computer.
4. Press and hold the Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
6. Release the keys.
After that, try to disconnect the battery and the MagSafe. Press and hold the power button for about 10 seconds. Then reconnect the MagSafe only. You should get a reboot. For now, keep the battery disconnected.
I would also try to bypass the power button by using the power-on pads on the logic board. Those two pads are located under the keyboard/trackpad cover. Remove that and you see the power-on pads. Use a small screwdriver to bridge the two pads which should then turn on your MBP.
Let us know what you find out.
Translation
Isabel teresa Rodríguez además de la gran respuesta dada por mi compañero @oscarsp me gustaría proponerte que comprobaras algunas cosas.
En primer lugar probaría con el reseteo estándar de SMC y PRAM de Apple
Reinicio del controlador de gestión del sistema (SMC)
Para resetear la gestión de energía a través del chip SMC:
1. Si el ordenador está encendido, apáguelo eligiendo Apagar en el menú Apple ().
2. Conecte el adaptador de corriente al ordenador y a una fuente de alimentación que funcione.
3. Importante: Utilice las teclas de la parte izquierda del teclado. En el teclado integrado, pulse Mayús-Control-Opción junto con el botón de encendido una vez.
Nota: Cuando el LED del conector MagSafe esté naranja, al restablecer la SMC cambiará a verde durante unos segundos, lo que indica que la SMC se ha restablecido correctamente.
4. Espere 5 segundos y pulse el botón de encendido para reiniciar el ordenador. Nota: Si se retira la carcasa inferior, puede restablecer la SMC desconectando el adaptador de alimentación y la batería principal, y manteniendo pulsado el botón de encendido durante cinco segundos.
Reinicio de la RAM de parámetros (PRAM)
Para restablecer la PRAM,
1. Si el ordenador está encendido, apáguelo.
2. Localice las siguientes teclas en el teclado: Comando, Opción, P y R. Deberá mantener pulsadas estas teclas simultáneamente en el paso 4.
Nota: Si el teclado no tiene tecla Opción, utilice en su lugar la tecla Alt.
3. Encienda el ordenador.
4. Mantenga pulsadas las teclas Comando-Opción-P-R.
Importante: Debes pulsar esta combinación de teclas antes de que aparezca la pantalla gris.
5. Mantén pulsadas las teclas hasta que el ordenador se reinicie y oigas el sonido de inicio por segunda vez.
6. Suelte las teclas.
Después, intenta desconectar la batería y el MagSafe. Mantenga pulsado el botón de encendido durante unos 10 segundos. A continuación, vuelve a conectar sólo el MagSafe. Debería reiniciarse. De momento, mantén la batería desconectada.
Yo también intentaría puentear el botón de encendido usando las almohadillas de encendido de la placa lógica. Esas dos almohadillas se encuentran debajo de la cubierta del teclado / trackpad. Quítala y verás las almohadillas de encendido. Utiliza un pequeño destornillador para puentear las dos almohadillas, lo que debería encender tu MBP.
Háganos saber lo que averigüe.
Espero que la traducción tenga sentido. @oscarsp tal vez usted puede editar esto para que ayude a la OP
@oldturkey03 Traducción correcta.
Estaré atento por si OP responde. Gracias por ayudar!
Correct translation.
I'll be watching if OP responds. Thank you for helping!
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 198
1 comentario
isabel teresa rodriguez what color is the MagSafe? What have you tried to fix it? What have you checked?
Translation
isabel teresa rodriguez ¿de qué color es el MagSafe? ¿que has probado para solucionarlo? ¿Qué has comprobado?
- de oldturkey03
