Phone is completely frozen.
The phone is completely frozen. No buttons work, touch screen don't work, the call time and clock is frozen also. What is the reason and fix for this????!!
Es esta una buena pregunta?
@oldturkey03, there was really nothing to tell. I tried to power it off the conventional way. But as I said, nothing was working. Even the screen had frozen in time. However, I was able to do a soft reset by holding all 3 buttons on the right side off the phone until it powered down and restarted. It is now working fine. Thank you for your response nonetheless.
Fue útil esta respuesta?
@warlock1515 Glad you got it working again. Sometimes even the best software glitches :-)
@warlock1515 you are not telling us what you have tried. Also, is there anything you know off that may have happened to the phone. Anyhow, her are a few things that you want to try first.
REstart the device
Should that not work try this
Press and hold the Power button and Volume down buttons (on the right edge) for approximately 10 seconds or until the device powers off. If your device doesn't automatically power back on, partially charge the device then press and hold the Power button until the Motorola screen appears.
Let us know if this changed anything.
When gets close 2 full apps stop working outta the blue and freezes up. Just delete few apps don't use much. And log out first
I took peacock off and another. No more problems since. Moto g pure!!
Yes is broken screen touch
@hnvzuf6vkdisl2w sorry but no it wasn't. The OP stated that "holding all 3 buttons on the right side off the phone until it powered down and restarted. It is now working fine." It is important to read through the complete thread.
Ultimas 24 horas: 9
Ultimos 7 días: 44
Ultimos 30 días: 224
Todo El Tiempo: 3,916
