Accessory port issues after SSD, memory, and processor upgrade
Components were shotgun installed, as this wasn't my first iMac teardown. Running fresh install of Monterey 12.6.1, no notable issues with OS or applications.
Only problem is that no devices are sensed when connected to the thunderbolt and SD card ports (one thunderbolt port occasionally cooperates with certain devices, but only after many repeated tries). I've tried multiple fresh installs of Monterey and Big Sur and tried resetting the SMC and PRAM. System Report shows that two thunderbolt ports and an SD card port are present. USB ports work perfectly fine.
I'm about to order a new logic board as I'm convinced the accessory ports were damaged during install. Was wondering if anyone here had any advice, or if they knew what specifically on the logic board could fail that would lead to thunderbolt and SD card port failure.
Es esta una buena pregunta?
